wildlaurel
hi all.. i have been searching for this pump for a while and cant seem to find any place offering it for less than $200.. anyone got the pump for cheap and/or can help in finding one/
of what i got from other forums is that if bought in bulk, per unit cost is reduced by a significant factor.. so i believe i ll have to gather a few others and order in bulk..
so anyone interested/
i tried hunting for the pump in the local market but all they have are the italian ones, while are huge and pretty expensive too..
yup.. its cheapest at jab-tech.. although i dont think cheap is the word one should use for it..
driving it wont be a problem with my custom made psu (40A@24V).. made it to support the TEC.. and with a pwm controller speed should be controllable too..
