- May 9, 2003
- 277
- 0
- 0
Hi all:
I'm putting together my first Ivy bridge rig and I'm noticing really high idle temps.
The build is an Asrock Extreme4 coupled with an i7 3770K and a CM Hyper 212+. I applied AS5 as per usual to the chip and greased the heat pipes very slightly to fill in the gaps. I'll admit it took me some time to understand how to mount the Hyper 212+, but after watching a few videos and reading feedback online I felt like I had a good understanding.
Anyhow, I mounted the HSF and in my BIOS I'm running steady at 41C idle. That seems astronomically high for one of the best aftermarket air coolers. It's the same temperature I was getting with the stock HSF, and the entire reason I bought the aftermarket cooler is because the stock HSF temps seemed way too high for comfort.
Am I doing this wrong? I will note one thing: when installing the CPU itself, I felt like I had to use an excessive amount of force to get the retention bracket secured. I've never installed an LGA1155 CPU before (I've only build AMD rigs for the past ten years) but I was really uncomfortable with how much pressure I needed to apply in order to get the retention lever underneath the hex screw that locks it into place. (The CPU itself slid right in without any problems.) Is it possible that I'm getting imperfect contact with the HSF, hence the temps?
