chloros Member Feb 1, 2011 95 0 0 May 1, 2012 #1 Am i doing something wrong? Last edited: May 1, 2012
I imaheadcase Diamond Member May 9, 2005 3,850 7 76 May 1, 2012 #2 4.5ghz vs 3.5ghz. You are not giving enough info, but from just that setting should give you a idea.
chloros Member Feb 1, 2011 95 0 0 May 1, 2012 #3 Actually the i had the IVY at 4.4 with my GTX 680. Not sure why its showing 3.5
T tato27 Member May 1, 2012 34 0 0 May 2, 2012 #4 its maybe wrong with 3d mark 11 the sandy ivy new tech wait for new virsion of 3d mark 11
Don Karnage Platinum Member Oct 11, 2011 2,865 0 0 May 2, 2012 #5 Disable Lucid MVP. Its inflating your score.
Subyman Moderator <br> VC&G Forum Mar 18, 2005 7,876 32 86 May 2, 2012 #6 Don Karnage said: Disable Lucid MVP. Its inflating your score. Click to expand... Yup, that graphics score is 5000 points higher than it should be.
