Endarkened
For a while, my 40GB IBM 60GXP worked just fine. Then, after a few months, I would be moving files around in My Documents, and for some reason it would just get extremely slow. Simply opening folders in My Documents would take 30 seconds or more, insane with my hardware specs. Strange thing was, it was only in My Documents that I saw such a drastic slowdown. Then, in the past few days it's been acting very strange -- completely restarting my computer for no apparent reason. The first time I noticed it was when I opened Exact Audio Copy. I was going to do some audio ripping so I downloaded it and when I opened it; my computer restarts. I thought it was the program's fault, so I deleted it quickly. Then, last night, I opened up SiSoft Sandra 2001 to check my CPU temps, and as soon as it opened, the computer restarts. Also, I left it on last night, and when I woke up the next morning, I could tell it had restarted again during the night because on the screen was the prompt to enter my boot password. So this morning I ran Norton Virus Scan and found that I was infected with the Nimda virus (not very suprising, considering that I've been sharing files across a campus network the past few months). So, I downloaded the Norton fix for that and took care of it. I thought I had solved all my problems. But no, when I opened up Sandra, *beep* it restarts. Sometimes I am able to get into Sandra w/out it restarting, and when I checked my scandisk log (since it runs it after every self-restart) I saw that scandisk found that the hard drive had been reporting the free space incorrectly, but it had fixed it or something to that effect. I've tried reinstalling Sandra, but that doesn't change anything. So, my question is what's going on? I'm completely baffled and it's getting very annoying. Any light you can shed on this predicament would be highly appreciated.
*update* - Left my computer alone for about ten minutes, heard a beep, looked over and it had restarted again. It's getting ridiculous. Please help.
Sorry to ramble on so long,
-EndarkEnd
*edit* - Changed title to something more descriptive of my problem.
-EndarkEnd
