I've got a 120mm case fan with a thermistor
Dec 27, 2001
11,272
How can I remove it and not destroy the fan? Can I just snip it?
This is a Globe sleeve bearing fan, but I want to control it with a controller.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
Shorting the thermistor leads together will give max rpm, leaving the circuit open will give minimum rpm... replacing the thermistor with a 10K or 25K ohm potentiometer, variable resistor, allows full range manual control.
Dec 27, 2001
11,272
What is the minimum RPM determined by?
Could I just snip the wire and add a 3pin connector on it and use a fan controller? Would be easier than having to solder on a potentiometer.
