- Nov 26, 2008
- 1
- 0
- 0
Hi there,
I've not been into using my PC for the past couple of years, and recently decided to upgrade my computer. I've bought a radeon 3870 but some other things have changed a bit, so have some questions I would really appreciate some help with.
I currently have an Asus A8n PCIe, socket 939 motherboard, with a single core Athlon 64 clocked@2.5ghz.
A Tagan 480w psu.
2gb of G-Skill 2-2-2-5 3200 ram (I think).
In order to play any recent games, I assume that the above set up will be pretty poor with a radeon 3870?
Would I benefit significantly from getting a multi-core cpu? (my monitor only works properly at 1680x1050). dual core cpus seem to be pretty hard to find for socket 939 now. Is it worth trying to track one down? or if I need a new cpu, what would be a good (AMD?) cpu for overclocking? I.e. what cheap cpu can be clocked at the same stable speed as a more expensive one?
Do I also have to get an AM2+ Motherboard? or is AM2 or some other standard ok?
Finally, is the above Ram too slow/incompatible with new Mobos, I remember it was pretty fast when I bought it several years back, but 3200 seems to be ultra slow now.
Thanks very much in advance for any help.
A Tagan 480w psu.
