ITX Case Build With Corsair H60 Possible?
nubian1
111
I'm ready to start my next build (S1155 i5-2500k based). It will be ITX based and due to my overclocking habit and just plain "tech-Giddyness" I'm aiming to use the Corsair H60 self contained watercooling unit to keep my cpu frosty.
Being ITX based and wanting to use this cooler I know that my options are limited so after much reading I've come up with the Lian-Li PC-Q11 & PC-Q08 mItx cases as potential candidates.
I would like to know if anyone can confirm that the Corsair H60 can be fitted in either case and if so.....How?
Blain
There are plenty of mini-ITX MB compatible cases that can handle the Corsair H60 with ease.
Zap
22,377
7
Don't remember with the Q11, but the Q08 has a 120mm blowhole fan at the top. Just remove that fan and mount the H60 in its place. The H60 has a slim radiator so it should fit without pressing against the PSU.
RaiderJ
7,582
I have some pics of a Q08 server build in my sig. Might give you an idea of how to put in a watercooling setup. Don't see why the 120mm blowhole wouldn't be perfect to mount a radiator to. But, might have some issues with PSU clearance. A micro-ATX PSU might help that.
Jen
24,206
14
only place to mount radiator would be to the front fan , no blowhole on the Q11. also need a short powersupply as well
Jen
nubian1
111
Jen
There are two real choices I've seen with respect to a shorter quality power supply both made by Silverstone and each in the $75 range.
Silverstone ST50F-P
http://www.silverstonetek.com/product.php?pid=274&area=usa
Silverstone ST45SF
http://www.silverstonetek.com/product.php?pid=253&area=usa
Both of these would probably fit the bill for a Q11 build. Another choice of case would be the Silverstone SG05 450w version which includes the ST45SF. The issue with that case is the mounted radiator leaving room for the slim DVDR to fit. I tink the solution maybe to mount the radiator, depends on which model you get, with the in/out tubing sideways. I'm not sure about this though.
jjmIII
8,399
You should snag up MaximumPC from last month. They did a multi-itx face-off, and some vendors did use water cooling. Some good info either way.
nubian1
111
WoW! Real sorry I missed that.........
I'll look for the article online.
Jen
24,206
14
Silverstone ST50F-P
Silverstone ST45SF
for my q11 i used a sfx silverstone 450 watt as it allowed more room .
Jen
terpsy
2,567
49
The Cosair H60 does NOT work in the Antec Solo Cases.
I found this out last night, and am searching for a new case as
well to house my machine.
aigomorla
21,067
3,575
Q08 u need to mount the rad up front where the 120mm fan would normally go.
Infact any spot which has a 120mm fan and some room at the end is golden with a H#O
nubian1
111
The build has been completed..............for the most part. Here are the list of components and picture links.
Silverstone SG05B-450 (450W uATX Power Supply)
Gigabyte H55N-USB3
Intel S1156 I5-760 CPU
8GB (2x4GB) G.Skill DDR3
Gigabyte GTX550 Ti Video Card
Seagate Momemtus XT 500GB Hybrid Drive
Corsair H60 Water Cooler
2x Arctic Cooling F12 120mm Fans
The system has become my main daily pc running Arch Linux with the Gnome 3 (3.2.1) Desktop. It is very stable and fairly quiet. I absolutely love this build.
It is a little messy cable wise but I have tried to make sure that the airflow behind the rad is as clear as possible. It, the cpu, runs surprisingly cool usually at just 5-7 degrees above ambiant during regular use. The rad orientation, due to the video card, blocks the use of an internal optical drive but is of little consequence since an external is used on those occasions where one is needed.
Gallery: http://imageshack.us/g/220/img072in.jpg/
dbrons
160
14
Nice job. I found the stock fan on the H60 quite loud and I replaced it with 2 Akasa Apache Blacks. They keep the cpu pretty much the same temp as the stock fan and are extremely quiet. It was up only a degree or two with just one Akasa fan so you might consider if that Corsair fan bugs you :)
Dave
nubian1
111
Why did you end up with the older socket?
At the time I purchased the components, a few months ago, I wasn't satisfied with the available S1155 based boards (H67 or H61) that were available. As well given that I would be running Linux exclusively, I opted for the previous generation for possible compatibility reasons. I should also mention that I got a great deal on the MB & Cpu!
The performance is very good for what I need it for but I may soon enough go S1155 (Z68 ITX) with a 2500K instead. There are a few more & interesting S1155 Itx boards available now.
nubian1
111
Dave
I found the stock Corsair fan too noisy as well and replace it with 2x Arctic Cooling F12's. You can see the white fan blades in the front photo of my build.
