Originally posted by: vital
What if I add 50 songs to 20 different subfolders? Do I manually click Add file to Library 50 times??
So I found ITLU through google. You can tell it to find new tracks that aren't in your iTunes library and also delete broken links. But it takes just as long as deleting your itunes library file and re-adding your entire music folder manually... 😕
Originally posted by: psynce
owning both the zune and ipod, monitoring folders just does not work for me.
i am a devote fan of total commander anyhow.
so for the itunes and zune software, i just use the drag and drop method.
creating playlists in itunes this way makes it a breeze and the inability to do so is the number one downfall of the zune software, imho
