Its cold outside, post your temps!
ChrisRey3156
135
So yeah 90 degree weather one day, wake up to upper 30's lower 40s in the morning. Good one Florida..plus no heater in the room!
anyway idle temps on corsair h100 in push pull:
For comparison, before today my idle temps NEVER went below 37 celcius on the 2nd and 3rd cores, and never went under 30 on the 4th core.
ctk1981
1,464
Eh, I have a back room thats almost a three season room.....I've had my phenom II X4 down to 17 before. Got tired of heating that room so I moved my computer down to the basement instead.
Thats with a H80 with AP-15 fans.
OVerLoRDI
5,490
4
6970s idle: 22-25C (basically a few C above ambient)
6970s load: 40-45C
CPU: same idle temps, load temps, just shy of 50C.
New radiators are getting here tomorrow. Temps shall improve :D
dr0be
197
Idle: 28/27/25/20 on a 2500k + Zalman CNPS9900MAX.
I watched your video ChrisRey about your H100 in your sig. I literally just bought mine a few minutes ago and hoping it can fit in my DF-85 - I did a lot of measuring. I think I will be placing the rad in push/pull on my rear 2 exhaust 120mm and remove a top 140mm that would be blocking it. If that doesn't work, on the newegg feedback, someone said with the DF-85 they were able to use the supplied washers to bolt it through the fan grill on top of the case, which produced no rattling or any noise and looked fine. Either way, should be interesting.
Smoblikat
5,184
107
LOL, youre complaining about 40's? I walked to school in 7 yesterday, and with the windchill it was -4. Derry, NH.
dr0be
197
He lives in Miramar, FL, according to the info below his username; which is literally the bottom of Florida. He probably rarely sees 40F.
ChrisRey3156
135
To Dr0be, yeah thats a good idea, in any case with some smart thinking you can fit in an h100 one way or another.
And yeah I'm in Florida, it was 80 to 90 degrees on average until now. It literally dropped 50 degrees in one day.
aigomorla
21,136
3,674
eh.. no one likes to play against me in this type of game...
^ u can see why.. :T
And this isnt on the freezing day either... i have colder temps... but that would probably make most of u guys cry.
Who doesnt want there 580GTX's in SLI to idle at 28C? :p
lsv
1,610
Mine aren't very good, ambient is maybe 25c~ but my system is silent.
