OK, this thing has officially taken over my life.
1. One fine day, my simple Workgroup at home stops working. My XP Pro desktop can see my XP Home Laptop and my wife's W2K Pro office laptop, but none of them can my W2K Server. But, my W2K Server can see them all.
Tried every trick in the book and couldn't get it to work and felt it was high time I progressed to learning a little more...
2. Used dcpromo to make my W2K Server a PDC. Had surprisingly few hitches and everything looks fine as far as the PDC is concerned.
My XP Pro Desktop cannot join that domain. But, I can add my XP Pro to that domain from the Active Directory Users and Computers Tool in the PDC and I am able to "Manage" my XP Pro from the PDC just fine.
Scenario:
I use a D-link router and all my computers sit behind it. It runs a DHCP server too but I use static ips for the W2K server and the XP Pro.
- The W2K Server PDC points to itself for primary DNS.
- The XP Pro points to the PDC for primary DNS.
- Both are on the same subnet.
- NetBIOS is enabled on both
- I am logged into the XP Pro using a local Administrator ID
- User Rights Assignments for Local Security Settings permits Authenticated Users to add workstations to domain
Why am I not able to join the domain from the XP Pro machine?
It's been three days and I can't take it anymore
EDIT: The errors I am getting are usually "Specifiec Network Name can no longer be found" and "The Semaphore time out has expired" after I enter the PDC Admin username/pwd while I try to join the domain from the XP Pro. I can ping fine from the XP Pro to the Win2k server <1ms
Scenario:
