IT guy here is incompetent
Captante
30,316
10,814
First if the PC's using 4gb's of RAM are running 32 bit versions of XP they can't make use of anything beyond 3gb's as far as I know because of OS limitations. Second running the laptop while using a CRT in a docking station won't make a bit of difference heat-wise.(however it will add life to the LCD on the laptop) Third, SCSI is a waste of money in non-server applications based on every credible benchmark I've seen in the last couple years which show it being significantly out-performed by ATA-100/133 & especially SATA in applications where the HD's switch back & forth from reads to writes frequently. (Large sequential reads are a very different story)
Savij
4,233
I thought 2^32 was 4 GB?
