issues with tv tuner card
zerocool1
When I put it into my computer, it doesn't detect my hard drives. Any ideas on what I should do?
Thanks
Amit
EDIT: Not sure if this is the right place for it, or tech support.
EDIT2: would work fine when tv tuner card removed. stopped booting altogether. changed ide cable, works fine. but using only 40 wire ide cable, still doesn't work though...not sure if I by mistake bump cable a littlebit or what, but it doesn't detect my hard drives still.
Originally posted by: Childs
IRQ conflict with the IDE controller? Some motherboards let you set them, you might want to try that.
I'm gonna try that later tonite. I use a KT7A from Abit.
I know its not something wrong with the card cuz it boots up fine in my P3 box
