- Jul 22, 2011
- 229
- 38
- 91
Ok, so this morning, when I went to turn my desktop on, the monitors did not turn on (I have dual monitors). The monitors didn't even acknowledge that they were connected to the desktop (power light never turned from orange to blue). I tried disconnecting them and toying with them a bit, and at first it didn't seem to help, then eventually, my primary monitor responded. I plugged both back in and it seems to be working ok for both monitors, but earlier today, it happened once again after coming out of hibernate mode.
I tried running a test on my video card to see if there was issues there, but the temperature seems fine and I let FurMark go at it for a good 4-5 mins. or so and the temp leveled of at 99C and stayed there.
Not sure what other tests I can run to find out where the problem is before it goes completely. Any suggestions would be greatly appreciated.
*One thing I did just notice is that when I go to use the colon, the shift button on the left side of my keyboard isn't working with it. Seems to work with all other keys but that one? Could a keyboard issue cause problems with the monitor like this, or could both issues be related to something like the motherboard perhaps?*
Here are my specs:
motherboard - ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD Motherboard
cpu - AMD Athlon II X2 250 Regor 3.0GHz Socket AM3 65W Dual-Core Processor ADX250OCGQBOX
ram - Crucial 4GB (4 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
video card - EVGA GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16
hard drive - Western Digital Caviar RE WD1600YS 160GB 7200 RPM SATA 3.0Gb/s
psu - XCLIO Goodpower 500w
sound card - Creative Sound Blaster Audigy SE 7.1 Channels PCI Interface Sound Card
cpu cooler - Rosewill RCX-Z940-SL 92mm 2 Ball
cd-rom dvd drives - LG 18x DVD+-R DVD Burner with 12x DVD-RAM
monitor - Viewsonic VX922 19"
keyboard - Logitech Media Elite
case - XION II XON-101
Here are my specs:
