- Dec 19, 2004
- 11
- 0
- 0
i feel that anandtechs article on xbox vs ps2 vs gamecube didnt go in depth enough, guessed at too many things, and intentionally got others wrong, not sure where to discuss this at, would like to get a thread going.....
"However details on this processor are sketchy at best but the information we've been able to gather points at a relatively unmodified PowerPC 750CXe microprocessor " - where did they gather this from? gekko isnt a PPC 750CXE or it would be marked as such.
"The Flipper graphics core is a fairly simple fixed function GPU aided by some very powerful amounts of memory bandwidth, but first onto the architecture of the graphics core. Flipper always operates on 4 pixels at a time using its 4 pixel pipelines; each of those pipelines is capable of applying one texture per pipeline which immediately tips you off that the ArtX design wasn't influenced by ATI at all. Since the Radeon and GeForce2, both ATI and NVIDIA's cores have been able to process a minimum of two textures per pixel in each of their pipelines which came quite in handy since none of today's games are single textured anymore." - who told them that gamecube only has one texture unit per pipeline? it wasnt nintendo, i could just as easily say it has 2, doubling texel bandwidth....... who said it was fixed function?
"Planet GameCube: In a recent IGNinsider article, Greg Buchner revealed that Flipper can do some unique things because of the ways that the different texture layers can interact. Can you elaborate on this feature? Have you used it? Do you know if the effects it allows are reproducible on other architectures (at decent framerates)?
Julian Eggebrecht: He was probably referring to the TEV pipeline. Imagine it like an elaborate switchboard that makes the wildest combinations of textures and materials possible. The TEV pipeline combines up to 8 textures in up to 16 stages in one go. Each stage can apply a multitude of functions to the texture - obvious examples of what you do with the TEV stages would be bump-mapping or cel-shading. The TEV pipeline is completely under programmer control, so the more time you spend on writing elaborate shaders for it, the more effects you can achieve. We just used the obvious effects in Rogue Leader with the targeting computer and the volumetric fog variations being the most unusual usage of TEV. In a second generation game we?ll obviously focus on more complicated applications."
The TEV pipeline is completely under programmer control, so the more time you spend on writing elaborate shaders for it, the more effects you can achieve. COMPLETELY UNDER PROGRAMMER CONTROL MEANS NOT FIXED FUNCTION, and on fixed function GPUs you cannot do advanced shader effects in realtime can you? rogue leader and rebel strike use them EXTENSIVELY.... anandtech.... wheres your explanation?
ill provide more examples later....
