Hey, first off, I'm sorry if this is the wrong section, I couldn't decide between this and Windows and Computer help, so I just kinda guessed.
Anyways, I recently got sick of using Fedora on my ACER aspire one Netbook, which previously had XP installed, so I am now attempting to put XP back on there. I'm using the aoD250 model, so there is no disk drive, forcing me to install via a USB flash drive. I've followed multiple guides, and right now I'm just using the Nov-Corp Windows to Flash program, because it seems to have the same effect as the others and is much faster. The problem is that when I start the first part of the install process, once it says "Starting Windows" in little gray text at the bottom of the screen, I BSOD with 000007B or whatever that code is. You know the one I mean.
I wiped the drive using KillDisk, and it still has problems. I can install linux fine, but XP is having problems.
I've done a lot of searching around on this issue, and very few people seem to find solutions. Anyone here have any idea what's going on?
