Issue with Samsung French door refrigerator/freezer
Cheri
I have a four-year-old Samsung French door refrigerator/freezer with the freezer on the bottom.
Not long after I bought the Samsung, some of the ice in the freezer started to clump up in the tray (I realize now that it was probably melting slightly), and more recently the freezer hasn't been producing much ice. The ice it does produce in the tray looks wet. About a month ago, the refrigerator stopped cooling, so we called a repair service, and the technician said it's a problem with the sensor. So he changed the sensor, but the fridge still didn't work. He came back and said that Samsung has a glitch in the system--one sensor affects the other (fridge sensor affects the freezer), so he changed the freezer sensor. The ice in the freezer continued to look wet and clumped up in the tray as usual, but the fridge never really cooled well.
Now, as of a day ago, the refrigerator doesn't cool at all and my ice cream melted in the freezer. I reset both the fridge and refrigerator, and turned on Power Cool and Power Freeze, and that brought the temp down in both, but not for long. All the food in the freezer is now defrosting and the fridge feels warm-ish.
Meanwhile, the sensor for the freezer reads -3F and the sensor for the fridge says -34F. Clearly, those readings are wrong.
Anyone have a similar experience? Any suggestions?
Moved from Off Topic.
admin allisolm
Number1
7,881
549
I have the same fridge. the fridge stopped working alltogether last week. It's 2 years old. I had to take everything out of the fridge, let the ice melt until I could get the back cover out.
When you check the temp, the initial indication is the set temp, you have to wait for a few seconds to see the actual temp.
Reactions: IGBT
herm0016
8,503
1,117
etc....
just as a reminder to others never to buy a samsung fridge.
Reactions: Number1
Cheri
Thank you! I've taken everything out of the fridge and freezer, unplugged the refrigerator, and now I'm waiting for a couple of days for it to defrost and hopefully reset. Did that work for you?
Number1
7,881
549
Yes, its working perfectly for now.
