For the past month I have been dealing with the most perplexing BSOD at work. I think I have boiled it down to this model of hard disk having a flaw in the way it writes and frees up HDD space.
Basically, we have machines that come in that are mostly identical that we reimage. I developed a Windows 7 image for these machines. The machines I am having an issue with have two 840 Pro's in mirrored RAID. Below causes a BSOD on every machine so far:
1. Boot using our version of Ultimate Boot CD for Windows.
2. Image with Ghost32 11.5.1 using the -IB switch.
3. Reboot the machine.
4. Do the OOBE.
5. Activate Windows 7
6. Run latest updates (since October).
7. Reboot.
8. BSOD.
Here is the most interesting part:
If i repeat the exact same steps. It does not blue screen on the 2nd/3rd/4th... etc. reimage. It only does it the first time.
I spent a few weeks finding a quick fix to the BSOD. We are running Windows 7 x64 and one of the catalog files was getting corrupt/unsigned. This same file is the issue each and every time with these drives following the above steps.
*If i repeat the process above but swap to intel drives i have no problems.
*If i zero the drives before imaging i have no problems.
*If i secure erase the drives before imaging i have no problems.
I finally did a raw copy of a set of drives (with the OEM load) before tinkering with the issue so i would have a baseline to work with. I somewhat expected not to see a blue screen if i did a raw copy back to drives i already used (i guess i assumed the drive wont be written to the same way twice). However, sure enough, if i applied a raw copy to an already used drive and then followed the steps above the machine would BSOD.
At this point my logic says it is most likely the drive itself. Yet, i considered it could be Ghost or some strange two variable problem.
My coworker thinks it is at least partly due to my image. If i understand his logic, he believes that it is improbable to think that an image being applied the exact same way each time, and across multiple sets of drives would have the exact same issue unless the image itself was corrupt.
I can find no other logical explanation. Therefore, i think that the opposite is true. The image is being written the same way each time and therefore is corrupting the same way each time. After spending hours learning about SSD... they operate completely different than spindle drives. So i think it is likely that it is corrupting the same way each time.
I know the EVO's had issues. Is it possible these do as well? Thoughts? Theories?
4. Do the OOBE.
7. Reboot.
8. BSOD.
