Ok, was out running around doing some work in prep for hunting season last weekend and my ATV started acting up. Started fine, and ran perfectly first thing in the day, but after riding around on it for quite a while, it started sputtering and missing, and eventually died. It would restart and idle fine, but as soon as I shifted into gear or gave it any throttle, it would die again. When it finally started and would run in gear, it had absolutely zero power, as in it wouldn't even turn the tires a partial revolution. So we parked it for an hour or so, and when we got back to it (after it sat cooling) it started right up and ran normally. The only time it has ever exhibited this behavior has been after an extended ride, so it appears to be heat (or otherwise usage) related, but I have no clue where to begin to look for answers.
Any advice is welcome...and it is not modded at all. I am the original owner and it is bone stock.
