Issue - corsair tx650w
boman744
35
I just upgraded my psu and gpu.
Installed gpu (gtx570) which eliminated some sata ports. I am only using the ports for my harddrive and dvd rom now.
My previous psu had a 4 pin connector that went to something called ATX_CPU on my mobo.
The corsair doesnt have this pin or anything that connects to this atxcpu. I had to eliminate it....
Closed case up and started pc up only to have it start for 1.5 sec and shut off (this repeats)
What could be the problem?
Level_1
37
There should be a 8pin EPS/ATX 12V (4+4 pin) CPU connector that you can split, use that for atx_cpu.
Look at the manual page 8 or 9.
Fallengod
5,909
19
Yeah, assuming this is the TX 650 V2(I own the same one), it has a 4+4 pin connector. So, one of those has to go to the motherboard or it is definitely not going to work..... My mobo has the full 8 pin connector, if yours doesnt, it may just be a 4 pin.
It was kind of a pain in the ass, cause the 4+4 pin dont connect together like they do with most other power supplies. I had to zip tie them together so I could easily connect them into the 8 pin socket.
I owned the corsair 750 watt v1 psu as well, and the 8 pin connector clipped together. Somehow in the newer version they opted to not have them do this? Retarded to say the least.
