slag
I have had an issue where I have a dead outlet in my house that is dead because an outlet in the other part of the house has tripped the built in GFCI. I am looking specifically for a tone generator that will allow me to hook up to the wire on the dead circuit, either by plugging something into the socket, or clipping on the wires attached to the receptacle, and then I can walk around the house until I find the offending circuit. Can I use a telephone pulse generator for this since the circuit will not be live? I'm wanting to keep this under $30.00 but all of the ones for AC circuits I've found are much more than that.
The way my house is wired, it makes no sense. I had an outlet on my front porch that was bad and the GFCI that was tripped was in the basement near my son's room, nowhere near the porch. Took a good 40 minutes to find it too. This is the second time this has happened, both to different outlets/circuits.
Most of the ones for phone lines require the tester to be right near the wire for it to sound. I'm looking for something that I can be standing about 3-5 feet from the socket and it will start to buzz so I know I'm in the correct vicinity.
I think I need something like this, but don't want to spend that kind of money.
https://www.amazon.com/Triplett-HotWire-3388-Circuit-Generator/dp/B0046SPMG4
