IS7 ghost random reboots. Help please!
Darland
Hello people!
I'm writing from Brazil, so sorry for the bad english.
I have this configuration:
Abit: IS7 (BIOS updated to 22)
Intel: P4 3.0 GHZ, 800MHz FSB
Kingston: KVR400x64C34/256 x2 Slots 1 and 3(Dual Channel)
Matrox: G-450 Dual Head (Video card)
Seagate: Barracuda 80G 7200 Sata HDD x2 (Raid 1=mirror)
Realtek: Lan onboard
Realtek: Audio onboard
Windows 2000 Pro (SP 4)
My problem is totally random and inexplicable reboots.
Some considerations:
1. In the power management on BIOS, "Restore on AC power loss" is set to power off, so I think that we can forget power supply failure, am I right?
Let me explain further, we have an ATX PSU 828C (http://www.sdc.com.br/Conteudo/Produtos/Anexos/ACE-828.pdf) powered by a 24VDC power supply. So I think if we have low voltage or power this BIOS config will make the mobo stay off, right?
2. The option "Automatically Reboots" is unmarked and I don't see a BSOD;
3. Some Bio settings. Ask if you need more details:
>> Bios Settings <<
Soft Menu Setup
Brand Name: Intel(R) Pentium(R)4 CPU 3.00GHz
Frequency: 3.00GHz
Cache size: 512K
x- Ext. Clock(CPU/AGP/PCI) 200/66/33MHz
x- Estimated New CPU Clock 3.00GHz
x- N/B Strap CPU as By CPU
x- DRam Ratio (CPU😀Ram) By SPD
x- AGP Ratio (CPU:AGP😛CI) Auto
x- Fixed AGP/PCI Frequency 66/33MHz
CPU Power Supply CPU Default
x- CPU COre Voltage 1.4750V
DDR SDRam Voltage 2.60V
AGP Voltage 1.55V
Advanced Chipset Features
DRam timing selectable By SPD
x- CAS Latency Time 3
x- Act to precharge delay 8
x- DRam Ras# to Cas# delay 3
x- DRam Ras# precharge 3
System BIOS cacheable Enabled
Video BIOS cacheable Enabled
Memory hole at 15M-16M Disabled
Delay Prior to thermal 16min
AGP Aperture size 128MB
Init display first PCI slot
AGP Data Rate capability 4x mode
Game accelerator Auto
All auto
PC Healh Status
Fan fail Alarm selectable Disabled
Shutdown when CPU Fan fail Disabled
CPU FanEQ Speed Control Disabled
x- Active Temperature 70ºC/158ºC
CPU Shutdown Temperature Disabled
CPU Warning Temperature 85ºC/185ºC
PWM Shutdown Temperature Disabled
PWM Warning Temperature 75ºC/167ºC
System Temperature 30ºC/86ºC
CPU Temperature 38ºC/100ºC
PWM Temperature 32ºC/89ºC
CPU Fan Speed 4963 ~ 5273RPM
NB Fan Speed 5625RPM
Sys Fan Speed 0 (independent)
CPU Core Voltage 1.44V
DDR Voltage 2.60V
AGP VDDQ Voltage 1.56V
DDR VTT Voltage 1.29V
ATX +3.3V 3.26V
ATX +5V 5.05V
ATX +12V 11.43V
Battery Voltage (+3V) 3.31V
Standby Voltage (+5V) 4.92V
Thanks for any help,
Alfadragon
Hi, Welcome to the forums.
To give us more idea about your problem,
See if you can do the following:
Control Panel
Administrative Tools
Event Logs
Look in the event logs for 'X' and '!'.
Post back to this forum with the SOURCE, EVENT ID, and any text that goes with the error with the same timestamp as the reboot.
Also, it might be worth disconnect all your drives except your main hard drive to see if it is a power issue
