IS7-G GAT. Need guidance/help
CyNics
270
Having a problem here hope you guys can guide me.
Whenever I enable the GAT, my memory would run at 160mhz and not sync with the FSB, which is 200mhz. I used CPU-Z to check and it displayed 5:4 in the FSBRAM box.
these are my settings
n/b strap = FSB800
divider= 1:1
AGP/PCI= fixed
GAT= F1
refresh cycle time= auto
read delay tRD= auto
read delay adjust tRDA= auto
command per clock CPC=auto
Memory timing=2-2-2-6
anything wrong?
I'm using the v1.6 BIOS
I benchmark it with GAT set to F1 (CPU-Z shows 5:4 divider) and the score is higher than GAT disable.
Set GAT to auto and CPU-Z showed me 1:1 divider back, but the score is lower.
Is this a CPU-Z bug or I din set the GAT setting properly?
system config:
p4 2.4ghz
is7-G
2x 256 TwinX
120gb cuda v
r9500pro
