Is "Write fault error writing device AUX" from OCing or using an old BIOS?
Feb 2, 2001
188
If your too lazy to click my system link I use an A7V rev 1.02.
I'm using 1003e4 w/ the Promise BIOS v2.01b35. Sometimes out of nowhere my system crashes to a DOS like screen and says, "Write fault error writing device AUX" w/ the Abort, Retry, Fail, and Ignore options. But I can't select them because the system is frozen. I don't see how this could be a result of OCing because it never did this when I had the UATA WD40GB HD on the IDE primary using the 1003e BIOS, the one w/ the Promise BIOS removed. I'm using the b25 Windows driver, I'll try updating that to b35 and see if this prollem continues. I can't up the core voltage if its ma OC because I lock up when Windows starts if I do that.
