F FearoftheNight Diamond Member Feb 19, 2003 5,101 0 71 Nov 19, 2007 #1 Is it worthwhile? The routers are over twice the price. Is it really twice the range and 5x the speed?
O oynaz Platinum Member May 14, 2003 2,449 3 81 Nov 19, 2007 #2 Well, maybe. The n is not standardized yet, so it may or may not run properly. My advice is to stick with g for now. Yoy can always upgrade when prices have dropped, and you can be sure that the hardware will work.
0roo0roo No Lifer Sep 21, 2002 64,795 84 91 Nov 19, 2007 #3 http://www.smallnetbuilder.com/ unless you get a cheap deal, probably not. 5x the speed is a stretch.....
JackMDS Elite Member Super Moderator Oct 25, 1999 29,546 422 126 Nov 19, 2007 #4 http://www.ezlan.net/faq,html#MIMO
