Originally posted by: Gillbot
Originally posted by: SickBeastI'm not dead-set against watercooling and I resent the comments about trolling.
I don't have to change my opinion just because you think I should.
You made the point that your $75 watercooling setup could not be beat by an air cooling setup, and I simply pointed out that watercooling is not even possible for $35. If it is, please show me, as I would consider it at that price provided that there was a zero percent chance of a leak and/or damage and/or my apartment catching on fire.
I didn't come here to argue. I was hoping to hear that watercooling does more than shave 5-10C off of CPU temperatures. I did not hear that.
Show me an air cooler that costs under $75 that can beat my watercooling setup. The shoe can go on both ways chief because the point is you can't show me one that cools MY CHIP BETTER.
Also, nothing is 100% safe. A fan on an air cooler can short out and catch fire just as easily as a watercooled rig can catch fire so your argument is moot.
If you weren't so dead set against watercooling, I'd sent you my setup for a test run and prove you wrong. But I figure you'd just sabotage it, report bad temps and claim it leaked. :roll:
Furthermore, I'm not trying to convert you TO watercooling. I couldn't care less if you do or dont. All I can show is hard and fast proof that FOR ME, it was 100% worth it for the nearly 20C drop in temps on my X3330 at 3.7GHz. Not to mention the fact that I could lower the voltage from ~1.45v for a stable overclock all the way down to 1.375v after switching to water. And before you try to argue, I put the air cooler back on to retest and it wasn't stable without the extra volts.
If you read my above post, I did show you examples of a $35 air cooler beating your setup.
Further, watercooling requires fans does it not? I don't see your point regarding a shorting out fan; that's really grasping at straws IMO.
