Is your system stable? That's the important question. I have a 1.8A running at 2.52 GHz with a vcore of 1.70 actual. (Set to 1.775 in the BIOS of my MSI 845 Ultra-ARU mobo.) At idle, my system is around 50 degrees Celsius. Under full load, it gets up to around 66 degrees. At first, I was really worried about this temperature. This is using a massive copper heatsink with a fast fan on the top, and the third re-application of AS3. (Since I lapped my Cooler Master IHC-H71 to a mirror smooth finish, I only used a slight haze of AS3 this time around.) I was getting really nervous that my system would crash on me because of the high temperatures. But after hours upon hours of Medal of Honor, Grand Theft Auto 3, and Soldier of Fortune 2, the system is rock stable. The load temperature does get up there, but it drops back down to idle temps within seconds of taking away the load.
Also, my temperatures never changed when I took the side off of my case. With the cover removed, there was no change in the system temp. or the cpu temp. So either my mo-bo is reporting the temperatures high, or my cpu just wants to run hot. Either way, I'm not complaining because my system is rock stable and running 720 MHz faster than it was rated for.
(Although it won't run stable at a higher speed unless I up the vcore some more. I really don't want to do that, so I'll just stick with what I've got.) So if your system is stable for your needs, then don't worry too much about the temperatures. (I'll have to admit, after six hours straight of Prime95, my system does lock up on me to where I have to manually reboot. However, I have never, and will never, have this thing under a full load for six plus hours at a time. Have too many things to do. lol.)
