Is this a writer problem?
deepakvrao
202
I have a Dell Vostro 1200 notebook which is about 5 months old and have noticed the following problem.
I often make copies of my own music DVDs and try to play only the copies so that the originals are not damaged. I use DVD decrypter to rip the DVDs, DVD shrink the DVDs, and again DVD decrypter to write the ISO file back to a DVD-R.
This was all fine with my previous Acer notebook [which I still have and still works fine] but with my Dell I occasionally get a DVD which just stops playing usually about half an hour into the DVD. The problem 'seems' less if I write at 1X but its not frequent enough for me to comment really. IO really dont want to burn so slow either.
How do I check whether its a DVD writer issue? or some issue with the blank DVDs? Like I said the problem is not in every DVD so its difficult to actually test it.
Any suggestions?
Thanks,
Deepak
Zepper
18,998
There may be a burner diagnostic utility you can download via MajorGeeks.com to help with that.
.bh.
