Is this a video hardware problem or a software problem? Please help!!!
atrus99
19
Hi everyone,
First here's my setup:
AMD Athlon T-bird 1.4GHz @1.533GHz
Shuttle AK31 rev 3.1 mobo
256MB Crucial DDR RAM
Inno3D Geforce3 Ti200 card w/ Det 23.11 drivers
Creative Soundblaster Live! 5.1 X-Gamer
Windows XP Pro
Now here's the problem: Everything was working fine one day. Then I used windows update and saw there was a new nVidia driver up. So I d/l'ed and installed the driver. Everything was working fine for a couple of hours. I went to class and then when I got back 8hrs later, the machine was dead. The monitor said "Please check signal" so I tried jiggling the cable, etc. Nothing. I turned the machine off and powered on again. Still nothing. There were also some beeps, 1 long and 3 short. I looked up that beep code and saw it relates to a video problem. So I removed the case and everything looked fine. Still, I reseated the vid card and powered it up again. Nothing.
I left the machine alone for a couple of hours and then tried it again. To my surprise, it started up and booted Windows. No unusual beeps this time. I rolled back the driver and removed all traces of both the old 23.11 drivers and the new 23.12 drivers from Windows update. I reinstalled the 23.11s and everything seemed to be stable. I went to bed and when I got up, the machine was dead again. If I power off the machine and leave it alone for a while, it will boot up and run for a while before it goes down. If I try to start up again just after it crashes, I get the beeps again. Anyone know what is going on? Could this be a heat problem? I don't think it's a busted card or CPU b/c they still work sometimes. If they were dead, they wouldn't right? Is this a driver problem? If so, how could this be since I removed all traces of the new drivers and am using the old stable drivers now? Any help would be appreciated, since this is really starting to get annoying. :confused:
Thanks for the help and sorry this is so long,
Dominique
Heisenberg
10,621
Sounds like a heat problem. Double check and make sure all the fans on your heatsinks (video card, processor, etc.) are spinning when the computer is on.
