- Feb 8, 2017
- 4
- 2
- 16
I have a "CoolerMaster Elite 460W", which has only one 6 pin pcie connector, and no 8 pin. but the 6 pin has 3 power wires (yellow ones), which is basically like an 8 pin connector without the two extra ground wires. Attaching this 6 pin connector to "MSI 1060 Gaming X" enables the card to output a black page with one line in it that says "...attach pcie connector..." (and when the connector is not attached, it wont output anything), so i'm thinking that the card checks for all the pieces, and wont work without the two extra.
So it got me thinking about doing this:
i have a molex to 6 pin adapter, i cut two of the 6 pins, and connect their wires to two black wires in a molex connector coming out of the psu (two middle ones). and then attach that to the two empty gpu sockets.
will it work? and is it safe to try? thanks.
