is there such thing as ethernet/wireless pcmcia card for laptop?
sirpado
404
is there such thing as ethernet/wireless pcmcia card for laptop? like one that can double as an ethernet card and also do wireless? I only have one slot....
erikiksaz
5,486
I think my sister had one. She was able to surf the internet without any connection to the desktop computer. Or was it just a modem, bah, i don't know.
obenton
2,012
There are internet routers, now, that have a wireless port as well as the usual ethernet ports.
blstriker
1,432
I've never seen a combo ethernet/wireless card. If they existed, they'd be pretty expensive I'm guessing.
jschuk
808
I have never seen one either. Nice thing about PCMCIA cards though, they are hot-swappable (through software) and they are only a few millimeters thick, so it doesn't take up much space to carry one around. If you must have both network devices connected at once, then you could get a USB NIC (limited to 10Mbps).
JackMDS
29,545
422
If your question is:
Can I find a PCMCIA card that can be connected to Network with CAT5 wire, and also can be connected Wirelessly?
The answer is NO.
If you Question is:
Can I buy a PCMCIA card that can connect to a Network's Access Point?
The answer is yes?
Example: ORiNOCO PC Card - Gold.
Want to know more about Wireless:
The Wireless Solution.
