Is there such thing as a whole-house UPS system?
Kaido
Feb 14, 2004
52,176
7,535
I think it'd be awesome to have the entire house on battery power, plus surge protection, so that all sockets give you full power, even for a little bit after the power goes out. Is that possible?
hypn0tik
5,866
Check out generators. However, you need to turn one on after the power goes. Not sure about a whole house UPS type deal though.
Viper GTS
38,107
433
Of course there is.
They have battery backups/generators for huge buildings full of people, a house is nothing.
Viper GTS
Aug 27, 2002
10,043
shouldn't be a problem, you should see the monster we use for our server farm at work.
(it's litterally the size of a VW bug and weighs as much as a 1/2 ton truck)
Eli
Super Moderator | Elite Member
8
Yes, of course.
Be ready with the lube though.
Feb 19, 2001
20,155
23
Generators is not UPS.
You get a UPS system like the ones they use in datacenters. Generators should kick in within 1 - 2 min so your UPS then can be turned off. Diesel/gas generators can run for like 3 - 4 days.
delroy
240
It is if you have a generator that is capable of producing the kilowatts needed to maintain your appliances, Gas or battery charged i think there are a few out there that could handle that load fairly well, though your compensation will be the noise that the generators provide. :)
At my office, there's a natural gas-powered generator that provides power for the entire building when the lights go out.
During the 2003 blackout, the building was used for an emergency operations center for the entire campus. It was very cool.
apoppin
34,890
alienbabeltech.com
Many Whole-house Solar Systems use backup batteries and even add generators for when the sun isn't 'out' . . .
(generators can run continuously for years) :p
:roll:
