Is there such a thing as a motherboard...
dds14u
1,310
Also, do people generally change motherboards when they upgrade processors?
Feb 17, 2005
4,300
i'd kill someone to get a mobo with both compatibilites. but theres several chips required for a particular cpu brand. you'll only need to change mobo if the processor has a different amount of pins then the mobo can support.
Crescent13
4,793
Yes! There IS a motherboard which supports ALL CPU's!! Sempron, X2, EE, P4, you name it. I will have a link soon.
link
IT EVEN SUPPORTS PM AND TURION!!!!
Feb 17, 2005
4,300
Originally posted by: KelComma
Yes: ECS PF88 Extreme Hybrid Intel/AMD Motherboard
since that problem is taken care of, im gonna go google for some performance statistics. bleh, you'll need a separate card to switch off cpu.
crockman
379
12
I have an Old MB a Gainward 5VPA, that supports AMD, Intel, & Cyrix/IBM, but it's Very Old Technology.
dds14u
1,310
link
Awesome possum.
But there's really no point in future proofing or anything by getting this is there?
imported_Stew
1,091
In general, new CPUs require new sockets, so people tend to upgrade their motherboards.
But, that ECS rig looks sweet....
batmanuel
2,144
I just don't have high hopes for the new ECS board.
It looks like you are going to be really limited in your cooling options with the daughter board that the alternate CPUs hang off. It's pretty obvious that you probably aren't getting an XP90 on to one of those things. A Zalman 7000AlCu is out of the question entirely.
Also, if the cost is too much for the daughterboad, you are likely going to be better off selling your old board and buying a completely new board for your new CPU.
