is there such a thing as a firewire hub?
thomsbrain
18,148
don't know much about firewire... but i built a peer-to-peer network (400Mb/s!!!) using it for guy. he only needs two computers on it anyway, but i got to thinking it would be cool if you could add more. are there firewire hubs?
thomsbrain
18,148
i really know nothing about firewire. is it one of those ones where you daisy-chain components? so you're suggesting daisy-chaining computers the same way?
edit: anyone know the cable length limitations of this stuff?
thomsbrain
18,148
<< I'm not sure about cable length limits, but I have found a hub that you can possible use. It's at http://www.evergreennow.com/category.cfm?Category=40.
I have never done firewire networks, but I think it would be sort of cool havin one.
That's really cool... I was curious about the cost versus Gigabit. My guess is firewire and gigabit adapters cost about the same, right? But a gigabit switch would cost a ton, I bet.
WalkingDead
1,103
yes there are firewire hubs & they cost $$$. You can just daisy-chain firewire together & save some money. I think you can daisy-chain up to 63 firewire devices together. The cable lenght limit is 15 ft between each powered firewire device.
At work, I have my firewire hard drive plugs into an external firewire Le Cie DVD-RW drive, which plugs into a Yamaha firewiire CDRW.
neuralfx
1,636
im not a firewire guy, but that firewire hub wouldnt work the same as an ethernet hub .. it just allows you to have more connections, it wont broadcast or anything ..
-neural
WalkingDead
1,103
oh wait, he is talking aboue Firewire Network Hub. I don't think there's such thing in the consumer level.
thomsbrain
18,148
<< yes there are firewire hubs & they cost $$$. You can just daisy-chain firewire together & save some money. I think you can daisy-chain up to 63 firewire devices together. The cable lenght limit is 15 ft between each powered firewire device.
I guess if you were daisy-chaining, then your speeds would go down the way they did with those old 10Base2 and 10Base5(?) networks. Plus, you'd have to have all the computers on, and functioning properly. Sounds like too much trouble.
neuralfx
1,636
well devices wouldnt slow down really, yes the power adapters would have to be on ... but this would not be a way to network computers using firewire .. it sounds like a good bus topology .. but it wouldnt work that way .. ..
-neural
