EDIT: Actually, now that I realize what I'm doing, I'm running the video out from my DVI output through a VGA cable via an adaptor into the VGA on the back of the TV. Do you think that's degrading picture quality at all?
Original post below
Which should I use to connect my HTPC to my HDTV - DVI or HDMI?
Here's what I think I know: the picture quality of DVI and HDMI is identical, but HDMI would have audio included (except for the fact that this is an HTPC, so audio output will be separate in any event).
But there are two issues that complicate this, I believe:
(1) By going through my TV's DVI port, I have less options for adjusting picture quality (it seems - anyone know if that's correct with this TV?)
(2) If I go through HDMI to get more options for playing with picture (120 Hz etc), how do I hook up audio if I'm going through the TV? I'm guessing I don't, and would need a separate audio system.
Advice?
Original post below
Advice?
