is there anyway to get direct tv to work w/ my TV tuner card?
Chau
712
4
i have a ATI Tv Wonder VE and i can't figure out how to be able to change channels on my tuner because i have Direct TV. The only thing i can do right now is set the card to antenna input and hook the cable into the soundcard coming from the output of the direct TV box, and i have to have the box on and can only change the channels from there and i have to set the tv tuner on channel 3. anyone know if thers anyway i can change channels from the tv tuner itself?
thanks
cproie
8
The tuner that is on the card is for Cable/Air ONLY. You can not change channels from the card when using DirecTV. If your receiver is in another room, a RF remote (if you receiver supports one) would be nice to have.
