cbn Lifer Mar 27, 2009 12,968 221 106 Mar 28, 2009 #1 My 550 watt modular PSU (Antec) has two 6-pin PCI-E power connectors. I am thinking of getting a HD4850X2 card but noticed it requires a 6 pin and a 8 pin PCI-E power connector. Is there anyway I could use this video card? Any adapters available?
T thilanliyan Lifer Jun 21, 2005 12,040 2,256 126 Mar 28, 2009 #2 You can apparently just short out the last 2 pins I think. Google it and read very carefully before you attempt it though.
MTDEW Diamond Member Oct 31, 1999 4,284 37 91 Mar 28, 2009 #3 http://www.newegg.com/Product/...x?Item=N82E16812198016
P palladium Senior member Dec 24, 2007 539 2 81 Mar 28, 2009 #4 or, use a 2x molex to 6-pin PCIe adapters, which should come with your video card.
MTDEW Diamond Member Oct 31, 1999 4,284 37 91 Mar 28, 2009 #5 Originally posted by: palladium or, use a 2x molex to 6-pin PCIe adapters, which should come with your video card. Click to expand... Guess i shoulda linked to the molex ones also, just in case you'd rather use one of those and dont have one. http://www.newegg.com/Product/...x?Item=N82E16812887002
