Is There Any Way To...
Crono
23,720
1,502
plus when you change providers, or move, you lose everything on the DVR!
Yup.
That's why the best possible solution - if you have a little money and time to spare - is to build a HTPC with a digital TV tuner. It gives you the best possible amount of space, the most options, and you can do whatever you want with your recordings (well, except redistribute them).
With a quad tuner, you can even watch and record up to 4 different channels at the same time.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
118
the cable company rents the box to you
OK. Can't you buy the cable box from the cable company? In Canada, we can do that....they are expensive but it is an option.
I thought OP meant he had to pay a fee to record shows.
