Can you get 60 fps at lower graphics settings? If so, overclocking the processor isn't likely to get you much.
Nope. B85 limitation. You can get faster RAM and lower the timing at 1600MHz, but it's 1600MHz max, unless MSI found a way around it.Can you up your ram to 1866-2133?
well i lowered the settings on titanfall and can stay at 60fps consistently ... put everything to medium and no aa.. 🙁((
is the r9 270 really not capable.. i mean it is a 170$ gpu lol
Nonetheless, OCing by clock is a bad idea. You won't get far, and you risk data corruption and stability with even small changes. A good OCing rig would have cost anywhere from $50 to $100 more, most likely, so that's the trade off with the B85 and i5 non-K.
It's a mid range gaming GPU. $170 isn't all that much when you consider what's out there.
