Question Is there any UPS where all outlets on the back are covered by battery and surge not just some?
pcslookout
11,959
157
I tried looking could not find. :( If it is not likely or a stupid thing to have just let me know.
sdifox
99,814
17,747
Most home ups come with one socket that is just filtered and not protected by the battery. Even my 1kva UPSes have one. Just add a power bar for the smaller things like router.
Or you can get something like this
I run an Eaton 9135 5KVA I got off an auction. Have another one and 4 expansion modules.
Raizinman
2,355
75
meettomy.site
Yes, I understand what you are saying. I purchased a Cyberpower or APC backup power unit and there just are not enough plugs on the back. Most of the items I need to plug in are VERY LOW WATTAGE for things like transformers for my router and similar things. I just plug in a 10 plug power strip and then plug the power strip into the backup power unit. Problem solved.
Stuka87
6,240
2,559
Just use an extension strip plugged in to the port with backup on it. Just be sure to not draw more than the UPS is rated for.
