Leopardos Senior member Jul 15, 2009 332 2 81 Mar 30, 2013 #1 As my title, I cant find anything in stores, there is just 1420mHa batteries (which is the same as the orginal one came with the phone) ... Thanks Last edited: Mar 30, 2013
B bearxor Diamond Member Jul 8, 2001 6,605 3 81 Mar 30, 2013 #3 Yeah, are you looking to replace the internal battery or An external battery pack? The battery is replaceable, but the phone is so tightly packed that you're not going to find larger capacities than the original.
Z zaydq Senior member Jul 8, 2012 782 0 0 Mar 30, 2013 #4 There are cases that add an extra 1500mah battery you can purchase.
S Suspicious-Teach8788 Lifer Feb 19, 2001 20,155 23 81 Mar 30, 2013 #5 external battery pack perhaps? these things are all the rage in Asia.
Leopardos Senior member Jul 15, 2009 332 2 81 Mar 30, 2013 #6 Will the external damage the internal battery? I heard that charging the battery when more than 20% will shorten its life in the future
B bearxor Diamond Member Jul 8, 2001 6,605 3 81 Mar 30, 2013 #7 You can turn the battery packs on and off. Just leave it off until your battery gets low then kick it on.
