is there any good deal on power supply with an case
simpsons
35
i was wondering if any1 knows about upcoming good deals on powersupply with case or without pc case if the price is good. looking to build a first pc but on a tight budget so i would like to keep the price is down however, reliable and good like corsair or something
simpsons
35
it's a mini tower isn't it? plus i have never heard of that website i dont know if its good or not
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
Directron's legit.
Been around longer than Newegg, that's for sure.
simpsons
35
is 430 watt able to handle my setup
GIGABYTE GA-P35-DS3L LGA
Intel Core 2 Duo E6750
G.SKILL 2GB (2 x 1GB
Seagate Barracuda 250GB
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
That board doesn't have on board video, so I can't tell you if the 430W will work. If it did, the answer is yes. But since you didn't say what you're using for graphics.....
With GPU's consuming more power than even CPU's these days, the deciding factor is your graphics card. If you're only going to have one card and that card doesn't even have a 6-pin PCIe power connector on it, you should be fine.
HOOfan 1
2,337
15
The Case Bladevenom linked you only accepts MicroATX motherboards....$120 for a MicroATX case and a 430 Watt PSU when for $20 less you can get a standard ATX case and a 500Watt PSU?
simpsons
35
i am planning to get a nvidia gt8600 or something lower for now, i think i ll go with corsair 550 $99 in newegg or buy.com where it is 68 after rebate
HOOfan 1
2,337
15
you mean CompUSA's website? I am pretty sure most of the CompUSA stores are gone now, unless you live in Florida. If you plan on replacing the PSU then you can get a cheaper and better case....just get a Coolermaster 690 or Coolermaster Elite
Zap
22,377
7
Originally posted by: jonnyGURU
Directron's legit.
:thumbsup: I used to score on Super Flower (TTGI) PSU deals from them years ago.
