generally nice power supplies don't come with cases, and nice cases don't come with power supplies. so, even if you do see a case with a supply labelled 600 watts in the box, it probably can't supply anywhere near that 600 watt rating.
coolermaster power supplies aren't anything special. i wouldn't put them on a shopping list.
Let me be the 1st to say the power supply isn't the place you want to shave $'s off the build. It's the heart of your rig and probably the most important part of it at the same time.
Most likely you'll be better off looking for a decent power supply 1st and then getting a cheap case to fit into your budget.
Okay! Then tell me which power supply should i get i want 600W?
My rig is
Core i3 2100
Intel DH67VR
4 GB 1333Mhz DDR3 Ram 7-7-7-23
350W PSU Currently
Looking for a GTX 570 should be 600W PSu enough for my rig
Antec Sonata 4 comes with a 620w Seasonic built PSU and they have some rebates going on right now. I built a friend's D3 box using one recently and it's just superb.
My rig is
Core i3 2100
Intel DH67VR
350W PSU Currently
Perhaps you would consider a completly new Build. because your cpu will be a major bottleneck on any cards beyond nvidia 2xx series, and ati, hd4000 series.
