Is there an integrated motherboard for Duron??
mikepers
10
I want to put together an inexpensive system. I'm looking for a motherboard that has integrated video, sound and ethernet that will support the Duron 800. I did a search in this forum but didn't see anything.
I could go with the Intel D815EEAL if I use a Celeron but I'd rather have the performance of the Duron with the 200mz fsb. Not to mention that a Duron 800 is only $85 and the only listing I can find for a Celeron 800 is for $180 bucks...
Any suggestions would be appreciated.
Thanks,
Mike P.
Biggs
3,010
There is and it's called the VIA KM133 chipset. I recently checked Asus's website and they already have a mobo using the KM133 chipset.
Noriaki
13,640
Asus A7VI-VM
The ASUS A7VI-VM Mainboard is based on the new VIA® ProSavage KM133 chipset with microATX form factor for the latest support in AMD® AthlonTM / Duron® 550MHz ~ 1.3GHz+ processors. This fascinating chipset is equipped with 200MHz Front Side Bus (FSB) with support for PC133/PC100/VC133 SDRAM, AGP 4X, Ultra DMA/100, 4 USB ports, as well as Suspend-to-RAM and PC health monitoring. Finally, with optional AC ' 97 audio and Realtek 100/10Mbps LAN, you can experience live 3D sound and accelerate your ethernet connection in business environments.
The VIA® ProSavage KM133 chipset is based on an innovative and scalable architecture with proven reliability and performance. It is a two-chip set consisting of the VT 8365 North Bridge Controller and the VT8231 South Bridge Controller.
[*]Supports AMD® AthlonTM / DuronTM 550MHz ~ 1.3GHz+
[*]2 x DIMM for up to 1GB PC133/PC100/VC133 SDRAM
[*]200MHz Front Side Bus and UltraDMA/100 IDE
[*]Dual Function Power Button & Chassis Intrusion Detection
[*]1 x AGP and 3 x PCI
[*]Wake-On LAN and Ring
[*]Stepless Frequency Selection
[*]Optional Audio and LAN
Noriaki
13,640
VIA® ProSavage KM133 chipset The KM133 is the KT133 with built in Savage2000 2D/Savage4 3D. It also supports and external AGP4x slot (like the i815E), it has video built in implicitly, it's not optional.
Audio and LAN are optional.
Wingznut
16,968
"Combining the proven performance and leading-edge features of the VIA Apollo KT133 chipset with the vibrant AGP4X graphics capabilities of the S3 Savage4? core, the VIA ProSavage? KM133 sets the new standard for power, scalability, and value for AMD Athlon? and Duron? processor based platforms."
I see.
mrbios
331
There is one board made by PC Chips, and its fairly low cost. It uses and SIS chipset. Here is a little copy/paste:
PCChips M810LR, Socket A, PC266 SiS 730S Chipset, 266Mhz FSB (MATX) w/ On-board PCI Sound, 128-bit AGP Video & 10/100 Network Adapter: $134.99
This is in Canadian Dollars, by the way, so if your in the States, it should be even cheaper.
Russell "Mr.Bios" Sampson
AmdEmAll
6,688
Im pretty sure OEM's are using these boards already. I saw in BestBuy and another ad that for a couple of the duron systems it said 64mb of SHARED memory meaning it has integrated graphics...
hans007
20,212
18
i'd get a km133 if i were you, its faster. the km133s are around $93 + shipping on pricewatch.
DickBurns
74
PC chips are junk! Not worth the headache they are garenteed to cause. I have built one system with a pcchips and had to fix two others and everything about them is terrible. Check out there website and you will see, it is the slowest site you will ever visit.
Asus is high quality and if your time is worth much than it is definitely worth the extra money.
Just my $.02
hans007
20,212
18
pc chips aren't that bad, they are even on amd's recommended list now. they've come a long way. besides the board is called amptron now. ANyways, the 810lm might be good if you get a revision 1.6 or higher. the revision 1.6 has the agp slot as optional. so if you get one with agp slot that is good. also for only $85 its a great, deal i didnt notice that it also had a built in lan card, which if you are trying to save cash will help you a lot. the problem is sis 730s chipset is slower by around 10% than the km133. plus the onboard savage4 on the km133 is much better than the onboard graphics on the 730s. if you are just building like cheapo computer lab systems i doubt it really matters, might as well save the $25 and get the 810lm over a km133 board and a lan card, and buy 128mb more ram . also the 810lm comes with a built in modem also.
MadRat
11,962
278
I think the 810 boards are wimpy but work perfectly fine. The 815 boards are so much more expensive. I don't think either one matters as far stable functionality goes. 810 is simply for cheap and nasty systems.
velvtelvis
162
I don't even wanna think about cooling a socket-A in a micro-ATX
I hope they don't give any overclocking options with those mobos, because people will be frying puters left and right.
formulav8
7,004
522
Hans. You need to look at the reviews anand did comparing the SIS and KM chipsets. He recommended the SIS chipset over the KM133. The Link
hans007
20,212
18
velvetelis...
i have a socket A 1000 on a microatx. It can be done and it can be done well. I was able to even o/c it to 1100 at default, but i'm back at 1000 now, since i really dont need the speed. 1150 overheated though with the case on. My comptuer is whisper quiet too, since i used the agilent arcticooler. maybe i could have gotten up to 1200 if i had used real heatsink paste instead of the thermal pad, but i'm lazy .
i wasnt aware that the sis 730s was faster than the km 133 now. i was thinking about the toms hardware review but i guess they fixed the sis730 so that its faster now
