gamefreakgcb
I ask this because I remember seeing such a device a while ago (I know it will be much more expensive than regular temp displays) Has anyone here ever owned of these things?
Originally posted by: Bluefront
IMHO....The LIS2 is super-high quality, good-looking, sturdy. The latest software relies on Speedfan to detect sensors. You can set the fan speed manually, or automatically based on CPU usage, or the board sensors. The fan speed is controlable from 0%-100%. You can set operational ranges for the speed based on temps. Each of the four channels is separately adjustable. Once setup, you can sit back and watch it do it's thing.
Some people have PWM fan noise. Others report software glitches. VL Systems is slow to implement bug fixes....and they don't translate English very well. My LIS2 is working fine for me.....
Thanks a lot guys, I am leaning towards the LIS2 and am cuttently on hunt for a good case before I I go after the LIS2.
Anybody looking for precision fan control, as well as water pump control, should look into M-Cubed products. The BigNG is their latest super fan controller......replacing the T-Balancer. I use the miniNG (only controls two fans). These things have an advantage over the LIS2 in that they can work with analog voltage, which is quieter than PWM.
The LIS2 does look neater though.....😀
Yeah thats the one I saw, is it reliable? build quality, features? accuracy in reading temps and controlling fans.
Luckily, the software for the L.I.S.2 MMCC (Multimedia Control Center) unit works perfectly with the L.I.S.2 Indicator model, and uses SpeedFan to monitor (and control if you enable it) temps and fan speeds.
Please clarify, if you hook up a couple of analog temperature sensors to the LIS2 hardware, can you read those temperatures in SpeedFan?
Similarly, if you connect fans to the LIS2, you can read and control RPM in SpeedFan?
If so, this might be the cheapest way to monitor a liquid cooling system by either using a supplied analog temperature sensor in the flow somewhere (i.e. the tank) or you could get one of those inline temp monitoring tees I've seen on Frozencpu and hook it up to the LIS2. It would be much cheaper than the M-cubed solution which requires their main module, an analog expansion module, and a water kit for about 250 Euro. I also wonder if the flow meter sensor's I've seen provide a signal fundamentally the same as a fan RPM monitor so you could use a flow meter sensor with the LIS2 on one of the fan headers to monitor flow. For $100 and a couple of sensors, it's worth trying.
Originally posted by: virtualrain
Actually, what Bluefront said is pretty much it, except that I think what he/she said could be taken out of context. It is true that the L.I.S.2 has no sensors of it's own - it uses the mobo board's sensors for the temp, fan speed, and voltage readings. And you do attach the fans directly to the L.I.S.2, but Bluefront said that doing so results in SpeedFan no longer controlling the fans. AFAIK, Speedfan reads the board sensors, and adjusts the fan speed(s) based on temps you set within the SpeedFan program. Thats was the way it worked with the old software that had MBM5 support instead of SpeedFan.Originally posted by: Aries64
There are three (3) "steps" that when reached change the fan speed - called SPEED01, SPEED02, and SPEED03, which the user can set. So SpeedFan still controls the fans, but the fans are hooked-up and powered by the L.I.S.2's fan headers instead of being hooked-up to the mobo headers and being powered by them. If yo want to be able to monitor the fan speeds while running the fans off of the L.I.S.2 headers, you'll need to use pass-through cables that allow you to connect the 3-pin wire from the fan to the mobo header and the headers on the L.I.S.2 simutaneously. Its' basically a long "Y" cable with 3-pin connectors. I actually preferred MBM5, becuase you could control fan speeds based on temperature, percentage of fan speed, or percentage of CPU used.
Yeah greakgreakgcb - that sounds like the best course of action if SpeedFan crashes your PC. The L.I.S.2 will control your fans via hardware, which works great. Its' weird - I used to have problems with earlier version of SpeedFan (at least thats what the source of locks ups seemed to be). Knock-on-wood SpeedFan 4.28 seems fine on my current system.Originally posted by: gamefreakgcb
I found that the SpeedFan fan control is very buggy, it clashed with my Bios setting no matter what I tried, so I will soon be getting the LIS2 once I am back from my trip.
