I have an AMD Opteron 165 that has worked perfectly - it runs at 2.4GHz no problem. I know this is crazy thinking, but I am thinking about changing to a lower wattage CPU in its place. However, I do not want to give up the performance of the OPTY. Ideally, I want to be on par, or exceed, its current performance. My goal in this upgrade is to get the maximum amount of performance at the greatest energy efficiency. By the way, I do not game tons - my system is used primarily for code compiles, symmetric data analysis, and some A/V encoding.
The first thing that comes to mind is one of the AMD 'BLACK' Athlon 64 X2s, most likely the 5000+. I am thinking this as I can overclock it easily to exceed the performance of the OPTY and it runs at 65W instead of the 100+W of the OPTY. The only drawback I can is the 512KB of L2 vs the 1MB of L2 in the OPTY - would I see that much of a hit?
What I don't know enough about are the offerings from Intel. Is there an energy efficient or lower wattage Intel CPU that would be on par, or exceed, the performance of my Opteron 165? If so, which one(s)? Also, can someone suggest a mobo to pair it with (does not need to be SLI either).
I know, that no matter which route I take, I will likely be facing a mobo + RAM upgrade (on top of the CPU) and I am fine with that. Again, my goal in this upgrade is to get the maximum amount of performance at the greatest energy efficiency.
