Do you want an accurate measurement?Is there an easy way to get a decibel measure of a PC's noise?
It'd be nice to have a measure of how loud a PC is, from where you use it or next to the PC.
Is there an easy way to measure the volume?
It's not a normal thing for someone to ask about measuring decibel levels around their PC. Not knowing your full intention is why I asked about accuracy. The main thing I needed to know was how accurate a measurement you required.Thanks, got this one.
http://www.amazon.com/BAFX-Products...=1451390776&sr=1-4&keywords=sound+level+meter
Don't know what's up with blain's unhelpfulness.
Measuring is easy.
Picking a uniform distance to measure from and compare to other's measurements is the hard part![]()
But don't you already have that information in your ears? 55 dB is meaningless unless you compare it to something else. It's just a number.
No, I don't. 55db is not meaningless unless compared, any more than "10 pounds" or "40MPH" are.
It's a more accurate measurement than 'seems loud'.
10 pounds is absolutely meaningless unless compared to something else. You need context to know what 10 pounds means. 40 MPH is not meaningless though - if you know what a mile is and what an hour is, then a mile per hour is a meaningless measurement in and of itself. But a mile is meaningless without context, and an hour is meaningless without context.
How do you know if 55 dBa is loud or not? If you know it's loud, how do you know how loud it is, exactly?
Look, we're not on the same planet, so I see no point in further discussion.
Craig234,
The problem is you are not associating a distance with the db reading.
Example - when private jets fly over my house when landing at the towns airport most are less than 50db because of the height.
So @55db is your PC louder than a jet?
I hope not.
All fans, graphics cards and heatsinks w/fans are usually advertised with a max db rating @ a specified distance, so that they can be compared to each other and so that you can tell if it will be noisier or quieter that what you have now.
Of course one of the oldest tricks in advertising is to slightly increase the "standard" distance used slightly as this will lower the db rating, making the object appear quieter than in is.
That's the reason the distance measurement is so important in a db rating and it should be one that is normally used to measure fans, graphics cards and heatsinks w/fans, so that a realistic comparison can be made, otherwise just using your is more than adequate.
