is there an easy way to demagnetize a screwdriver?
Eli
Super Moderator | Elite Member
8
Originally posted by: thirtythree
Originally posted by: Eli
Torch.
Don't melt the handle. :p
I'm assuming a lighter wouldn't be enough?
It might....
In that case, don't blow your hand off(by keeping the lighter lit for minutes at a time)... lol
thirtythree
8,680
maybe I don't really need to demagnetize it, but I've heard it's bad to use a magnetized screwdriver on your computer. it's only powerful enough to hold one tiny screw up...
JoeKing
bah I wouldn't worry. I've been using magnetic screwdrivers on computer for years. Nothing has gone wrong as far as I can tell, and they're a really convenient way to get those itty bitty screws that can get away from you.
Eli
8
Oh, lol.. It's fine.
They're magnetized on the tips for your convienence.
nageov3t
42,808
83
it's not going to damage your computer... just annoy the crap out of you.
/hates magnetized screw drivers
Crucial
5,026
I won't build a pc without one. The magnetized screwdriver is one of the greatest tools ever.
0roo0roo
64,795
84
u'd need an much stronger magnet right next to a platter to mess up a computer. magnetic fields drop way too fast with distance to do squat, let alone a screwdriver.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
Originally posted by: Shockwave
Hold the handle and sharply slap the blade on the ground. That'll get most of it.
Yep.
Little physics. Using an induction coil, you can magnetize a ferrous, nickle or a couple other elemental metal objects. The reason for magnetism, and why using an induction coil works is that a strong enough field will "polarize" the metal atoms so that they all face a certain direction. Once polarized, each atom no longer has a random magnetic field, rather they are all polarized into the same direction making the resultant field stronger and pronounced.
Okay, so how do you unmagnetize something? Well, you have to randomize the metal atoms in the object so that their individual fields are not all polarized. You will never completely get rid of a polar magnetic field on an object, but it can be weakened to an extent where it's almost non-discernable (ie: only able to pick up tiny grains of dust). In a solid metal object, you have to either melt the metal (high kinetic energy + randomization) or whack the object several times hard enough to "knock" enough of the molecular atoms around to weaken the field.
There, that was fun.
BTW: I don't suggest using an induction coil to magnetize something without a strong vise or something to hold the object. One word: railgun. :D
Shockwave
Banned
Sep 16, 2000
9,059
Yep.
This man speaks truth!!
I may know Jack Schitt, but one thing I DO know is magnets. Father owns his own magnetic fabrication plant :D
i worked there all through high school, as much as I hated it.
cquark
1,741
Torch.
It might....
The Curie temperature of iron is 1043K, and even though the various alloys of steel have lower Curie temperatures, I'd doubt that the lighter would work.
Eli
8
Yep.
Damn... It must've sucked to work in a magnetic factory.. Your tools always flying out of your hands and sticking to the walls and sh!t....
:p
Torch.
It might....
1043ºK = 1417ºF... so, yeah.. probably not with the lighter. ;)
shiekh
Torch.
You may lose any heat treatment that way; I have some nice <This looks a lot like spam to me> screwdrivers that are forged and heat treated.
13,673
Rub a hard drive magnet on it.
To remagnetize put it in a coil and apply DC power. I usually use the 12v rail of a computer psu. Make your coil a couple ohms and the psu will not see it as a short and not shut down. I usually leave it for like 30 seconds.
Feb 25, 2011
16,992
1,621
Yeah, no danger to a computer.
And a non-magnetized screwdriver is like $0.50 at any hardware store, Mr. OP who was a cheapskate 11 years ago.
EliteRetard
6,490
1,021
2004? Yeah this seems relevant:
twinrider1
4,096
64
Wait, bring Shockwave back. I want to hear more about working in a magnet factory.
