Per the subject line, I'm wondering with modern CPUs that have an IMC, if there is an appreciable temp difference between the two configurations?
I know on my LGA 775 systems, the Northbridge ran significantly warmer when I had all 4 DIMM slots populated. Also along the same subject, how about voltage? I know low voltage DIMMs themselves would run a bit cooler, but would it have any effect on the CPU?
I'll be able to test this out for myself later this week when I help a friend build his setup. I have 4x4GB 1.5v DIMMs and he will be running 2x8GB 1.35v DIMMs. (both 1600mhz) Going to run 10 passes of IBT and log temps, then swap his sticks in my machine to do another 10 passes and compare.
Anyone done a similar comparison already?
