- Jan 31, 2005
- 9,454
- 0
- 0
Like it says. Is there anyway I can put a wireless device of some type on a cable line to send my cable signal around the house wirelessly?
Originally posted by: MrBond
There's a bunch of options here:
http://www.smarthome.com/prodindex.asp?catid=303
I don't know how good they are. I can understand hating pulling cable. When I build my house I'm going to make sure every room has cables for anything I think I ever might want in there.
Originally posted by: BrunoPuntzJones
I bought some 2.4Ghz stuff at Radio Shack for $50 and it works great, can't even tell it's wireless. Going through two walls and about 40 feet. I'm sure you could run them in a series to extend the range.
I'm sure X10 makes a ton of that crap.
Whoops, blank post.
Anyway, I don't think they make a wireless cable/data router. The 2.4ghz wireless video things just happen to work on the same spectrum as wireless internet (so it'll cut into your bandwidth if you're surfing/streaming video at the same time).
If it's coming from a cable box, it will only display the signal being shown then. Most of the ones I've seen are just cables you hook from the video out port to the device. You'd need either an RF remote relay or a cable box with a built-in RF remote.
If you're doing this for cable TV, it might be worth it to have the cable company come out and do it for you. I think mine charges $25 per jack to install, so if I had a particularly nasty cable run I'd just call them rather than spend an afternoon with a fish tape.
Originally posted by: ViviTheMage
when I build my house I will have cat5es running through the walls too![]()
Originally posted by: Sphexi
There is no way to send the full cable signal coming out of your wall to somewhere else wirelessly, at least not with what's available to consumers. The signal coming out is modulated, meaning that all of the channels are on a slightly different frequency. It'd be incredibly difficult to take all of those frequencies, combine them and send them off over a single frequency to a receiver somewhere, then split them back apart again.
What you can do though is send the output from a cable box/VCR (composite, or S-Video), since it's only a single audio/video signal, as opposed to dozens. The transmitter/receiver will usually have a remote extender built-in, so you can control the VCR/cable box from the other location. That would be the easiest and cheapest way.
