Is there a way to test an AT power supply by its leads?
WetSprocket
543
I need to test an AT PS and would like to test it by the leads. How do I activate the switch so that I can test it? What's the best way? Thanx
Noriaki
13,640
AT?
AT has a hard switch....
you just press the switch.
Or do you mean ATX w/ soft power?
SCSIRAID
579
Switching power supplies dont like to run with no load on them. It may not start without a load and max exhibit poor regulation with a light load.
Oyeve
22,066
883
Put your tongue on the leads, if it knocks you on your ass, then, Hey PS works! :) J/K
WetSprocket
543
Here's the thing. It was in a friends computer. I went over to check it out. I checked all connections, all cards, cpu everything I could think of. And it acted like it wasn't even plugged in. I was just wanting to know if there is a way of testing the power supply without it being connected to a motherboard?
Budman
Since you said it's an AT power supply,i will say it again louder.
Just connect a case fan & flip the switch if the fan turns then the power is good
Noriaki
13,640
Yeah what budman said.
An AT PSU has a hard switch. Flick that switch with a fan attached.
If it comes on it it works. If the fan stays off it doesn't work.
Sundog
12,342
On an AT case, the PS is already hooked up to the power switch. So in your friends computer, unhook all the power connections (mobo, fans, CD-Roms, everything), hook-up one case fan and hit the main power switch to see if the fan starts.
WetSprocket
543
Wow this is weird. It has the same connectors as an AT PS, but it doesnt have a hard switch. It has an extra power connetor like a small floppy but it only has 3 wires. Damn proprietory crap. Anyone know about these, it says it is Tiger Power(AI-2200). It came out of an HP or Compaq or something like that. And if it is the power supply how would I get another one?
Jiggz
4,329
It must be one of them relay operated AT PSU. Unplu the unit and unmount the PSU. Opened it up and check for continuity of the wires with the switch and the relay.:cool:
